Work from home LJ
Got my renewal in the mail today. Vehicle value: $833. Tax bill due: $29.
This is the first time a tax valuation has been in my favor 😂😂😂
That's interesting. What did NC have you at? I just renewed mine valued at $2,630 and cost $65.71
I hadnt renewed my LJ in NC since prob 22 iirc. It wasnt drivable for awhile during the axle builds and was on jack stands for months when I was recovering from torn acl/surgery for that. $150 bucks or so sounds about right.
Reactions: BlueC
Yep. Same here. Mine drips and will leak on the ground / on the skid plate. But has never been low. I’ll feel better in after a few more hundred miles
Did you find your leak?
Mine dripped just a little after my SYE install. It turned out to be the speedometer sensor. Even with it's O-ring. I put a small bead of sealant on the SYE housing and reinstalled the sensor. It's been dry since.
I did. Took awhile but ended up replacing tailhousing seal (if thats correct term) with one directly from advance adapters. Never leaked again. No idea if the random parts store one I was using was bad or just slightly small.
Reactions: InOmaha
Guy down street pays 2500/yr for his ‘23 6.7 HO. SC doesn’t have vehicle sales tax (capped at 500) so they try to say it evens out.
It doesn’t 😂
Had I got an F250 it would have been based on value.
One tons are fixed fee, cause farmers.
  • USA Proud
Reactions: lBasket
NC does a standard % fee which covers vehicles up to 6,000lbs, then a weighted tag fee is added per 1,000lbs above for the tag. My truck alone is on the books at or above the 6K limit, so I run weighted tags to cover my ass.
Reactions: Illiquid
Haven’t done much on the jeep recently besides drive it. Wife takes it to the pool on the weekends and I drive a few days a week when it’s nice out.
4 years of ownership was few weeks ago. Have put less than 4k miles on it during that time. Hope to 2-3x that in another 4 years!
Havent posted in awhile. Jeep has been fine. Most its ever been driven. Probably 500 miles in last few months! But its due for a little love.
* Driver rear axle seal is leaking a little - no big deal, have parts on hand for this. Few hour job
* Transfer case still leaks a bit - its only a small leak and i havent been motivated enough to rip it open and fix....maybe once its wheeling season again
But the most interesting of all - my cluster and HVAC lights went out. Tail lights are good. No blown fuses that I can find. Going to start chasing grounds next unless anyone else has a better idea.
I have odometer still, just no lights in dash with headlights. Either bad ground or a headlight switch?
  • Sad
Reactions: FarFire70
I have that issue too, so will follow along. Mine happened with the auto swap so thinking likely in the column (multifunction switch?)
Reactions: Illiquid
The switch was going to be my first attempt at fixing. Mine went after jeep was sitting for weeks so I have a hard time believing it’s a ground
I have a humming sound from my rear sound bar when I turn the cab lights on.
No chance that’s unrelated. It might be a loose ground then
