WJ Tie Rod End Taper
Andy-WhiteTJ
Poughkeepsie, NY
Is the Tie Rod End taper of the WJ TRE the same as TJs? I did the WJ conversion on mine years ago and did the TRE flip and used GoFerit inserts. I need to rework the passenger knuckle and need to re-install a new insert but can't remember (time is NOT on my side) if the insert is the same for the WJ and TJ.
@mrblaine you are the initial expert on the WJ conversion. What say you?
TRE's are the same taper. 1.5" per foot.
