I have a Jasper in my Wrangler. Solid, no leaks just works. I'm pretty happy with it I've driven 5k miles in a year though so not much. I've had maybe 3 oil changes.
I don't hesitate to go anywhere with it. Just make sure you do the cooling system too, you might have other things give for example, my coil pack had to be replaced as well, I got misfires on a cylinder. IACV also swapped because it wasn't idling smooth. Mechanic said since the engine is the strong point now the weaker things started giving way, which imo makes sense.
