Can someone tell me what this part is and does? It’s on the right side of the engine with two foam connections on each side. One of the connections has come loose so I need to replace. Does it have anything to do with the heating system.
I ended up replacing this as it came completely off and was hissing. I still don’t know for sure its purpose. I do know my heat only blows at my feat and defrost. Not sure if this line affects that.
Yes, if you have a leak in the vacuum lines it will cause air to blow out only the defrost and the floor pans.
Is there one particular line that causes this behavior? Would be great if I could isolate this down. Thanks for your help!
I traced the line from the firewall to the T and then it goes to the 2nd picture. Should that 2nd pic be connected to something?
After a trip to your local eye doc, try this.That’s looks like line for sure but I don’t see any open ports that’s don’t already have a connection. I posted picture of the ports on my intake. The red line is one I just replaced because the rubber boot was broken. Wondering if my intake has a port that I’m not seeing. Still looking.
