What caused my tailgate to crack?
XCRN
Springfield OH
So before I go spending money on the wrong thing. Was this a lack of snubber support on the tires or a poorly reinforced tailgate? Keep in mind its a stock sized Rubicon tire, but I also had some hard hits up at Silver Lake Sand Dunes and is where I noticed it. I do not know if I should get something to extend the snubbers, better tire carrier, or one of those fancy tailgate reinforcement/hinge kits. The tailgate is like 2 years old.
Regardless of tire size, this will happen if the snubbers are not fully contacting the tire. It just happens quicker with larger tires.
Tailgate reinforcement like the Exogate/Morryde is probably overkill for stock Rubicon tires. Extend the snubbers and you should be good as long as your carrier isn’t cracked as well.
Not sure what to tell you about the tailgate itself.
Reactions: James9100
X2 to all of this.
It's hard to say for sure, but I suspect this had something to do with your spare tire not being properly snug up against the tailgate. That's the only thing I can think of that would cause this.
Looks a lot like the Jeep was backed into something... the top of the tailgate looks to be pushed in/buckled, and the metal around the latch handle is distorted badly too...
Reactions: TJ4Jim and BlueC
The gate on my 91 is cracked the same way. It was bone stock when I bought it years ago. Best fix is to buy a real spare carrier/bumper combo.
Stock jeep ugly alloy wheels with 235's and all the snubbers. In the 6 CJ/TJ/YJ vehicles every one had a damaged, in some form or another, tailgate, body (old CJ5) or carrier from a tire hanging off it. IMO its kinda what happens when you use a jeep in the dirt.
Stock jeep ugly alloy wheels with 235's and all the snubbers. In the 6 CJ/TJ/YJ vehicles every one had a damaged, in some form or another, tailgate, body (old CJ5) or carrier from a tire hanging off it. IMO its kinda what happens when you use a jeep in the dirt and don't take the weight off the tailgate.
Fixed that for accuracy.
Which is one reason to lose the spare tire.
Reactions: TheBoogieman
Until you cut a side wall and you're far from your tow rig.
I've heard rumors of having these people around that can help with that. I think they call them friends. I wouldn't know about that. I go everywhere alone and never ask for help, even if I need it. It builds character.......and resentment. :unsure:
X2 to all of this.
How much pressure should the tires be up against the snubbers?
