I have an 05 Rubicon TJ that has a clunk feeling in the steering. I have narrowed the culprit to the slip joint on the upper steering shaft located at the fire wall. My question, can I drill and tap a set screw in the slip joint, or is this joint meant to be telescopic to make up for movements during normal operation? And, if I cannot do the aforementioned fix, which I am pretty sure is a no-go, is the Borgeson the only option...or are there better options for this repair? Thanks in advance!
