Unknown connector
oogah
Kansas
This connector is between the washer fluid pump and headlight connectors, all I see in the fsm is a ambient air sensor but the one I have is plugged in and I never unplugged it, any help is appreciated
Replaced them with some led pods, looked and the fsm, it says its the ambient air sensor for temp/compass. Think that's for the display on the rear view mirror but I don't have it on mine so I'm trying to see if it ever was connected to anything
Have a look here, and see if that's the factory fog light harness that others are mentioning. They may have been pulled up from the wheel well into the engine bay, which is why the FSM might not mention it in that location.
What color are the two wires coming out of the back of the plug? That will tell all. The closest two I could find are....
Reactions: JMT
Even if you don't have the mirror, the sensor plug is usually stuffed behind the headlight.
However, yours looks like it was plugged into something.
Unless you wiped the dirt off before the picture was taken.
Honestly can't remember and I most likely did, and the fsm says the the wires for that sensor are light green/ violet and white
Got a better look at the connector wires and one is purple and yellow, the other is purple and blue
