Turbo Kit Test TJ
Can you give a +-$500 price swag? Will it start out as a base kit with options or is this a turn key minus tune?
Yeah, it will be right at 5k for everything minus the tuning. That does include the air to water as well as injectors and a MAP sensor.
Also, I did manage to source an intercooler from a different supplier. It should be here in a few days and we will set it up on the jigs to confirm fitment. Good news is if it fits they have more than 50 in stock.
This is a bit off topic here, but I thought it deserved a mention. The topic of spool and lag comes up frequently when turbocharging is discussed. When a modern turbo is properly sized for the application and paired with a free flowing intake and exhaust spool time is reduced to a minimum. Most folks remember the 80s cars with the huge lag times. The newer computer designed and optimized turbochargers are worlds away from those 80s designs. This is a video I took this morning on my LJ. The basic parts of my LJ system are similar to the kit. My LJ has a much larger turbo and 3 inch exhaust. Other than that it is a stock 4.0 with a 42rle running about 5psi of boost. This was flooring the throttle from a dead stop. Boost is up over 4psi within 2 seconds of being throttled up. Please excuse the poorly shot video and my messy vehicle. 🤣
I'm going to need more videos haha.
I think we have stablished this kit in stock form will be no good for a RHD due to some of the differences of layout in the engine bay. I would though be very interested in the parts list, included which are off the shelf and which you are having fabricated. That way I may be able to work out how much could work and what would need to be reconfigured for RHD.
Reactions: Wildman
What ever happened to the turbo kits?
Both kits have sold. We will be reordering turbos asap and I will let everyone know when they are back in stock again.
Dammit! Forum members? That’s what you get for thinking about it… same thing happened w/ Savvy parts a while back🙄
I'm not sure the distributor would be a problem, but the a/c compressor would be in the way for sure.
Reactions: SkylinesSuck
I must have missed it, why can’t this kit work with the earlier years?
Somehow I missed that as well. So I guess I'm outta luck with '97 which has a 4.6L Golen stroked '92 block with 7120 head and '97 PCM stock tune?
