Transmission pan leak
Nemoracer
Sweden
Hi I have a small atf leak when I park car,I have changed atf and filter a couple months ago and take mopar rtv sealer and now it’s leak a little.
What is the best? A gasket,Witch is the best brand (material)or should I do rtv again,maybe I take too little?I was afraid to take to much so it go inside the pan,I have a new pan and torch to spec
//Martin
//Martin
X2 on Lube Locker… if you don’t want lube locker the rubber gasket will work, no rtv, and torque to 13 foot pounds…
I also use LL's every chance I get, but are you CERTAIN it's a pan leak? Virtually every transmission leak other than one inside the bellhousing will run to the pan, making it look like a pan leak.
comes in a thin cardbaord envelope. I have 3 on my Jeep, 3 on my wifes and 2 on my truck, all shipped from amazon w/ no issues.
I use lube locker rather than RTV, I use this brand on my diff's as well. Only need to buy once and no need to wait for the RTV to cure.
[URL]https://www.amazon.com/LUBE-LOCKER-LLT-A042-Lubelocker/dp/B00BOU6UJA?tag=wranglerorg-20[/URL]
Thanks everyone,have ordered one hopefully it’s coming not damaged
Reactions: 97JadeTJ
Same. I have 10 LL's installed across all my jeeps. Their packaging is heavy cardstock, never had an issue.
