i wanted to add a rack to the back of my TJ for holding stuff. Something modular, low profile, and clean. I mounted two Rotopax toolboxes, but they could be swapped out for fuel, first aid, water... whatever. It would also be easy to make an adapter for skis, a mountain bike, or whatever else you might want to hang off the back of your jeep.
I started by having some 12g plate bent into a C to form the main backbone, then added tabs top and bottom...
Basic, nice and simple...
Well, functional, the tabs are not straight...
and the heat from welding warped them. Oh well, still not bad right?
No, this is fucking garbage. So I cut the tabs off and did it right...
I started again with two 12" long C channels made of 1/8". Tapered the ends, drilled the holes. These are proper and sturdy..
Then I cut grooves in the main C to slide over these brackets and welded them together. The right side is longer so I can add an antenna mount, or bottle opener, or whatever. Drilled holes for the Rotopax mounts and...
Cheap, easy, and a rainy afternoon worth of work.
