98 Wrangler 2.5 Auto. Gauge cluster works sometimes, only on nice days. Cluster doesn't work if it is raining or the humidity is high. It will work if disconnected from the battery for a period of time but if the jeep is turned off it won't work unless disconnected again. I Have replaced fuses inspected grounds, cleaned connections, and inspected the cluster itself. Everything appears to be fine. Any help is Appreciated. Thank You!
