Teraflex End Link 1600493
Budxr7
MA
Ordered these to go along with a ~2” lift on 04 LJ.
First observation, on the sway bar side, the link doesn’t “seat” into the thru-hole like the stock links. They did come with a small sleeve but that doesn’t fit in the sway bar. I haven’t tightened them yet but I thought they would need to press in and they’re loose.
Second observation, the axle side of the links do not come with a metal bushing to insert into the rubber. So I banged the originals out to reuse but the OD is way too small. Even tightened all the way, the rubber doesn’t compress on to the metal bushing. Are both these end links missing the bushing from teraflex? Both of the plastic wrappers inside the box had already been torn open so I was suspicious.
