I've been working on a way to bench test one with an Arduino (which obviously everyone has lying around) but while it worked in the sim, it did not work on the bench so I've tabled that for the time being.
Interesting. If you ever want a 2nd set of eyes on your code/circuit, message me. I do know my way around arduinos and H-Bridges. No pressure though, sometimes the best projects need a timeout on the healing shelf for a bit, while they hopefully fix themselves.
Anyway, you've replace this much, why not it, too?
Yeah... Just trying to limit the total replacements. Each sensor/part is not that expensive on it's own, but add them all up, on top of having to redo most of the suspension/steering already... Just hoping to stick with firm maybes now instead of soft ones. My wife has come up with this weird idea of 'figuring out how much that Jeep has cost you' which I find just absurd, but it's worrisome if that type of thinking spreads. haha.
Remember that all these sensors run on basically the same 5V & ground, so if one is problematic it can affect the whole system. There are a number of posts on this forum talking about a rough idle that ended up being resolved by replacing the clock spring. I've never traced the circuit, but I guess it shares that same 5V & ground as the CPS, CKS, , etc and there's some evidence that it can cause a rough idle.
I did read that a failing clock spring can add a bunch of noise to the circuit, and mess with a bunch of the sensors. My thought was to borrow an oscilloscope at some point and see how noisy that circuit is.
It's also very possible you've got one or more semi-shorted wires buried in the harness somewhere. In my experience I can all but guarantee you do; every jeep does. Whether or not it's the culprit I obviously can't say. Just one more thing to consider as you troubleshoot.
This is my worst fear. I have a bad habit of going all or nothing. So it'll be a nice easy find, or I'll end up with the body off making a new wiring loom from scratch during an engine rebuild. :S only half joking.
Good luck, these are always fun to track down.
Haha. Indeed. Cheers, and thanks for the input.
