Worn out cam? Springs? Push rods? Rockers? Timing chain - er 2.4 so belt.
This is the gravel driveway mechanic in me asking questions...
When was the timing belt changed? Tensioner?
Also wondering if when it's at TDC and the valve is leaking if you can physically grab it and wiggle it up and down.
Rings and a quick hone?
Anything stamped on the pistons to indicate they're 10 thou over?
So you're 6 to 7 thou over spec, you have 2 thou larger pistons? I don't see the mm on there...so I'm assuming 5 thou over which liberally would get you in spec.
You could throw new rings on. You could just try number 4. You could do a quick hone and replace the pistons. You're there anyways so at least rod bearings.
Or find a machine shop to bore it out, order a $2000 stroker kit and send it. Maybe you'll have better luck with machine shops in your area.
Or maybe it's time to shop around for something used or a short or long block.
Clearly seems like you've got the time and enough know how to make some good decisions. I don't know what's in your budget... time or money wise.
Wish I was closer to upstate NY and could help.
I keep thinking you've got a 4.0. Just stuck in my brain.
No idea if you can stroke a 2.4...technically if you're 5 over that's approaching the limits...I think. I don't have much expertise with the 2.4.
Good news you'd only need 4 pistons and bearings!
When I totalled my TJ last summer the replacement frame was a 2.4. I cut off the 2.4 brackets and my 4.0 brackets on my bent frame and welded them on.
If you've ever looked at the welds on our frames a kid could do better.
Metal is thin enough...you can also preheat with a propane or butane torch for more penetration.
I bought my frame and tub for $1300 in Oregon. I'll bet you could get a hot shot trucker to deliver something to you for $1000 or less.
