Shuddering
johnnyblaze
Riverside
My TJ shudders between 30-40 mph then levels off after and drives smooth. Does anyone have any ideas why this might be? My tires are good and i redid my u joints on my drive shaft. If my alignment is off some can this be the problem?
My TJ shutters between 30-40 mph then levels off after and drives smooth. Does anyone have any ideas why this might be? My tires are good and i redid my u joints on my drive shaft. If my alignment is off some can this be the problem?
Sounds like a tire balancing issue. Does the steering wheel shimmy along with the "shuttering" between 30-40mph?
I hate shittering?
Not much its the dash that shutters mostly the steering wheel vibrates some bit when i let off the gas it settles then when i gas it does it again
That sounds more like a driveline issue. Can you tell us what's been done to the drivetrain? Does the Jeep have any of the following:
suspension lift, tummy tuck / raised belly skid, transfer case drop/spacer, motor mount lift, adjustable rear control arms, slip yoke eliminator?
I thought it was my dive shaft also so I replaced the U joints on it,could it need rebalancing again? I have a 6” lift
6” lift? What is your pinion angle? SYE?
Stock drive train? Rear axle placement stock?
Going to be hard pressed to get that DS happy.
Reactions: LONGJP2
jeeps used to be my dads so not sure what is stock or not stock, everything on it is aftermarket so im sure its upgraded.im still learning and doing the work myself.dont know the pinion angle have bought a reader yet, i know when i had 33’s on there it was good and when i went to 35’s my problem started
Dude we need pictures and measurements.question is way too broad. (No we don't need to know about your old ladies bowel movements)
Reactions: L J
We may be jerks but we do want to help. No gold stars but you can get answers here 😉
Reactions: L J and Gollywomper
I dont know how to go back and change the I to a u lol didnt see it til it posted
It happens. A moderator will be along soon enough.
Take a few photos of the drive line both where it meets the differential and the transfer case. As well as a complete shot from the side showing all in one photo.
Reactions: Rickyd
