My TJ shudders between 30-40 mph then levels off after and drives smooth. Does anyone have any ideas why this might be? My tires are good and i redid my u joints on my drive shaft. If my alignment is off some can this be the problem?
My TJ shutters between 30-40 mph then levels off after and drives smooth. Does anyone have any ideas why this might be? My tires are good and i redid my u joints on my drive shaft. If my alignment is off some can this be the problem?
Not much its the dash that shutters mostly the steering wheel vibrates some bit when i let off the gas it settles then when i gas it does it again
I thought it was my dive shaft also so I replaced the U joints on it,could it need rebalancing again? I have a 6” lift
jeeps used to be my dads so not sure what is stock or not stock, everything on it is aftermarket so im sure its upgraded.im still learning and doing the work myself.dont know the pinion angle have bought a reader yet, i know when i had 33’s on there it was good and when i went to 35’s my problem started
I dont know how to go back and change the I to a u lol didnt see it til it posted
@Chris or @Jerry Bransford should be able to help
