The cowl adds +5hp if you have a cold air intake
10 if you get a sticker
37lbs. How much does a factory cut hood weigh?
According to AI between 31 and 36 lbs.
Shipping weight from extreme terrain says 80lbs https://www.extremeterrain.com/omixada-replacement-hood-98early-00-jeep-tj.html
Must come n a crate.
If we estimate about 40lbs for the hood, then remove the 5lbs of sides after a highline, we are not left with much of a weight savings
If we estimate about 40lbs for the hood, then remove the 5lbs of sides after a highline, we are not left with much of a weight savings.
Unless Savvy is listing 37lbs shipped weight.
Can’t wait to see it unpainted on a stock 4 cylinder TJ along with a Fab Four grumper grille and windshield surround!
16 lbs vs 40 lbs (claimed stock weight)
https://varozza-4x4-outfitters.myshopify.com/products/fiberglass-hi-line-hood
The good hood is available from Campbell directly. And you can see the original TJ buggy hood this is based on.
https://campbellent.com/fiberglass-products/
They hate us cause they ain’t us.
That makes sense why the description on Savvy's website sounded like Campbell was producing it.
I wonder if Campbell really is producing a variant that is specific to the Savvy highlines. One thing I know about highlines is that every installation is going to be a little different, which means every one of these hoods is going to require a bit of fitting. Which then suggests that this hood will work with highlines other than Savvy.
