Rear pad noise(FIXED)
The shoes are dragging and chattering. Have you tried adjusting them until they slightly drag?
This is on a d 44 I bought out of a really clean 2005 lj,I had Dan in St. Louis do the gears I installed it with new calipers ,pads and hi carbon rotors,can’t figure it out,anything you can think of -thanks
Put the rear on jack stands and idle it in gear. Watch the calipers and see if the rotor is moving them back and forth.
it was these clips,the one on the drivers side was too tight,binding the pad.just installed pads that didn’t have them,problem fixed
