Preferred oil pan gasket
xXDavidCXx
AZ
What is the preferred 4.0 oil pan gasket?
I just put on a Felpro gasket and when I was test fitting it, there was excess length around the hump of the RMS, which is now where it is leaking slowly.
Felpro is the only one I've ever used. I think I RTV the corners, but I can't remember if I do the hump.
I rtv'd both, but admittedly had to pull the pan off after the first set due to clearance issues with the starter, which I removed.
It's entirely possible I ruined the RTV, but I feel it's worth checking with the collective minds.
