Just out of curiosity, what color is he?Now my GF can’t breath, the mother fucker that hit us is no shit named George Floyd.
White. Typical suburban parents have money kid.Just out of curiosity, what color is he?![]()
I tried the gas auger 1 time, my ground used to be an old river bed. Second hole I hooked a big rock, digger spun around, thru me to the ground, broke 2 ribs. I guess I gave it too much gas. I hired a guy to finish the holes.At that point I would just not build a fence.
Mine ended up 330 feet including the 60 I had already ran. Rented a 1 man auger from home depot. Out of 27 holes attempted with the auger, it worked well for about 6 of them. Another 6 or so it worked ok if I ran it for a bit, filled the hole with water, did some other work and came back to it after soaking. Some required a few soaking cycles because 30 minutes after pouring 3 gallons of water into the hole, 6 inches below the surface was still bone dry. The rest it would hit a root and just spin and not make progress, or would grab it and take me for a ride. Twisted my right arm pretty good on one of them; took me a good 30 seconds for the pain to subside enough for me to decide it wasn't dislocated. Had to cut a few roots with a sawzall. All of them had to follow behind with the clamshell diggers for the last few inches. Had a couple times where I had to disconnect the motor and screw the auger bit back out of the ground. All in all I'm not sure it saved me any time over the clamshell diggers, it just used different muscle groups.
All the holes are dug at least, but I have 3 more posts to set. I miscalculated my length and came up short by 2 line posts, but I have 2 extra gate posts because I was able to re-use the posts from the gate I took out. Just have to drill through the post to make holes for the rails but my drill battery only made it through 2/3 of one post.
I counted 48 trees inside the fence.
Well then, you could have killed him without much repercussion.White. Typical suburban parents have money kid.
Our car officially totaled!!!
I did something right because the alternator is working. On the other hand, I found the oil leak I could never find before.It’s been a real pain in the ass to put a 6v positive ground GM alternator into the 1948 DeSoto.
That is all.
Miserable gauling cheap azz SS bolts!In my continuing shock saga, I bought new stainless bolts to get everything installed. I touched up the paint on the shock. The first bolt went in smoothly, where the bolt head had broken off on the right side in my photos. On the other side, it when half way in then promptly snapped off. So I know the left side must have gotten cross threaded at some point and didn't tighten all the way down. That's what started this whole mess.
Of course, the stainless bolt broke off further up and I couldn't get a grip on it. I eventually got a pilot hole started and drilled a big enough hole to try an extractor, gave up rather than break it off in there, and drilled the whole thing out threads and all. Then I dropped a larger bolt, with a 1/2 inch smooth shank, in from the top and put the shock on with a nut and washer on the bottom side.
The tighten down 2 bolts in 5 minutes job, ended up finished in about 2 hours total. I spent less time then that on it, because I needed to step away for a moment or two and vent rather then break something else.
Luckily the temperature had dropped from hell's fireplace to a reasonable 75 F with a breeze.
I'll inspect the setup a couple of times to make sure everything is still doing it's job, then find a rubber cap to put on the threads sticking down so they don't rust shut if I decide to take the shock off in the future. If it does rust, a sawzall will remove the bar pin to allow access to the bolt head and I'll add bar pin eliminators rather than mess with these little bolts.
My initial assessment is the Jeep handles/corners better and rides nicer with all 4 shocks installed.
The 72 year old generator system took a dump. At best, it was good for 35 amp output, and wouldn’t charge at an idle. Couldn’t see squat at a stop sign on a rainy cool evening when signaling a turn. Radio would quit playing, too.I'm confused. A 6 v *ALTERNATOR*? I'd have thunk it would be a generator - what's the story?
Too bad, being stupid should hurt, it drives home the lesson better........Farming on a state highway has its perils. Being passed while turning left has happened countless times and normally we catch it before completing the turn. Not today. Nobody hurt!
That is what Charlie Brown said a few pages back and I think he had that right.Too bad, being stupid should hurt, it drives home the lesson better........
