Piss & Moan Table
Agreed on the moving part. Today's temp here. Insane!
  • Wow
Reactions: mrjp and Rick Flair
Yikes. We were 90 today, which is about as hot as I've seen here. Low on Tuesday is 24 and they're calling for 3-6" of snow. Guess I better disconnect the water hoses.
Our last snow accumulation was June 8th, so it'll 3 months to the day.
  • Wow
Reactions: Rick Flair
At that point I would just not build a fence.
Mine ended up 330 feet including the 60 I had already ran. Rented a 1 man auger from home depot. Out of 27 holes attempted with the auger, it worked well for about 6 of them. Another 6 or so it worked ok if I ran it for a bit, filled the hole with water, did some other work and came back to it after soaking. Some required a few soaking cycles because 30 minutes after pouring 3 gallons of water into the hole, 6 inches below the surface was still bone dry. The rest it would hit a root and just spin and not make progress, or would grab it and take me for a ride. Twisted my right arm pretty good on one of them; took me a good 30 seconds for the pain to subside enough for me to decide it wasn't dislocated. Had to cut a few roots with a sawzall. All of them had to follow behind with the clamshell diggers for the last few inches. Had a couple times where I had to disconnect the motor and screw the auger bit back out of the ground. All in all I'm not sure it saved me any time over the clamshell diggers, it just used different muscle groups.
All the holes are dug at least, but I have 3 more posts to set. I miscalculated my length and came up short by 2 line posts, but I have 2 extra gate posts because I was able to re-use the posts from the gate I took out. Just have to drill through the post to make holes for the rails but my drill battery only made it through 2/3 of one post.
I counted 48 trees inside the fence.
I tried the gas auger 1 time, my ground used to be an old river bed. Second hole I hooked a big rock, digger spun around, thru me to the ground, broke 2 ribs. I guess I gave it too much gas. I hired a guy to finish the holes.
Working from home the past three years has meant I usually took vacation to see scattered family, bicycle or motorcycle camping, or just hopping on a plane to go somewhere different. This year, phhhtttt! Since moving to the new place, my time off has been honey-do around the house and setting up my garage(didn’t mind that one).
This week, we were planning a couple days of motorcycle camping. During a summer of drought in NE Illannoy, I picked a week of steady rain.
Reactions: Phil Younger
In my continuing shock saga, I bought new stainless bolts to get everything installed. I touched up the paint on the shock. The first bolt went in smoothly, where the bolt head had broken off on the right side in my photos. On the other side, it when half way in then promptly snapped off. So I know the left side must have gotten cross threaded at some point and didn't tighten all the way down. That's what started this whole mess.
Of course, the stainless bolt broke off further up and I couldn't get a grip on it. I eventually got a pilot hole started and drilled a big enough hole to try an extractor, gave up rather than break it off in there, and drilled the whole thing out threads and all. Then I dropped a larger bolt, with a 1/2 inch smooth shank, in from the top and put the shock on with a nut and washer on the bottom side.
The tighten down 2 bolts in 5 minutes job, ended up finished in about 2 hours total. I spent less time then that on it, because I needed to step away for a moment or two and vent rather then break something else.
Luckily the temperature had dropped from hell's fireplace to a reasonable 75 F with a breeze.
I'll inspect the setup a couple of times to make sure everything is still doing it's job, then find a rubber cap to put on the threads sticking down so they don't rust shut if I decide to take the shock off in the future. If it does rust, a sawzall will remove the bar pin to allow access to the bolt head and I'll add bar pin eliminators rather than mess with these little bolts.
My initial assessment is the Jeep handles/corners better and rides nicer with all 4 shocks installed.
Miserable gauling cheap azz SS bolts!
I feel your pain, used them on the semi mud flaps thinking I was saving myself grief.....but instead caused more. Now just never seize.
I'm confused. A 6 v *ALTERNATOR*? I'd have thunk it would be a generator - what's the story?
The 72 year old generator system took a dump. At best, it was good for 35 amp output, and wouldn’t charge at an idle. Couldn’t see squat at a stop sign on a rainy cool evening when signaling a turn. Radio would quit playing, too.
I converted a GM-Delco10si alternator from 12v negative ground to 6v positive ground. Output is now 63 amps and everything works like it should at an idle.
Before anyone asks why I just didn’t go 12v negative ground, I have a working five tube radio and the electrically shifted semi auto transmission on the car. If not for those, it would have been done years ago. I could probably do a work around with the radio but there isn’t anything I can do about the relay, solenoid, or governor on the transmission.
Hell, I had a similar situation making a left turn in my CAR! Nothing got hit, but horns were blown - idiot making a left behind me ignored my turn signal and cut the corner by 100 feet or so, then was shocked when I turned in front of him...
A Hooter's waitress running late for work once tried to pass my wife while turning left. Her clapped out Buick hit the step tube on my 6" lifted full size Bronco, bounced off, entered the ditch, and was stopped abruptly by a utility line pole. Everybody was ok and the damage to the Bronco consisted of a streak of white paint that I rubbed off with my thumb, but the weak-minded officer responding to the incident ticketed the driver that wasn't in a Hooters uniform shamelessly flirting with him...for not using her turn signal, solely based on the waitress' word. Being that, turn signal or not, it's illegal to pass within an intersection, she was clearly at fault so it only took a quick visit with the DA and a call to our insurance agent to clear it all right up.
