Hey Folks,
Looking for some advice. Recently received a code for P0344 and limp mode. Ordered a ThinkDiag2 to check timing and the Cam Crank Difference was at 9.10 degrees but Cam Sync State showed In Sync. I adjusted the ODPA to get within 0.5 and forced a relearn. After some driving, I have realized I can get the P0344 to pop (along with limp mode) any time I go WOT.
Today I pulled up the live monitors on the ThinkDiag2 for Cam Crank Difference, Cam Crank Last Lost, Cam Sync State and CrankSynk State. Starting out on the drive the Cam Crank Difference was 0.90 — as I went WOT this went to 2.40 before finally popping a CEL and going to 6547 (which from another thread I realize is a negative value and a shortcoming in the ThingDiag2).
I have read various threads concerning the issue, I have checked wires and I am not getting any other CELs. I don't think this is a wiring issue or ground issue as I can only replicate at WOT. I dont feel any slop in the timing set by turning the crank bolt. Could this be the ODPA by chance? I also dont think its the sensor (which I assume is the original Mopar sensor) since it can only be replicated at WOT. Any ideas on where to look next? I do have a Crown ODPA coming soon.
Some quick details:
- 2005 LJ Automatic
- 160K Miles
Appreciate any advice.
Thanks,
Some quick details:
- 2005 LJ Automatic
- 160K Miles
Thanks,
