O2 sensors or PCM error - are these values correct?
Alliance2000
Avondale, AZ
Hello everyone!
I bought a 2005 TJ Rubicon where the seller told me the CEL was on due to 4 cheap China O2 sensors - the error codes (he showed me via OBD): P0031, P0037, P0051, P0057.
I checked here on Wranglerforum and got 4 new O2 sensors from RockAuto:
- NTK 23158 (downstream, cyl. 4-6, bank 2 / sensor 2)
- NTK 23159 (downstream, cyl. 1-3, bank 1 / sensor 2)
- NTK 23160 (upstream, cyl. 4-6, bank 2 / sensor 1)
- NTK 23195 (upstream, cyl. 1-3, bank 1 / sensor 1) - this is the "newer" version of NTK 23018, the only one offered from RockAuto.
After installing them - still CEL with 3 of the 4 codes above: P0031, P0037, P0051 (read via VeePeak OBDCheck BLE+ with CarScanner App).
Today I checked all O2 wirings:
- All 4 sensor harness plugs have a common ground with good connections (G105 at lower right engine block - looks good and tight).
- All other 3 connectors of each 4 sensor harness plugs have good connections to the PCM connectors (harness side), no wrong grounds - so wiring should be good.
- When sensors are connected to the harness, the heater control pins have a connection to ground, all with 4.6 Ohm (Wrangler manual: 2-30 Ohm) - so heaters of the (new) O2 sensors should be good.
- PCM heater control connectors (at the PCM) have 3x about 75 kOhm against the PCM ground (C2 - pins 17 and 18, C3 - pin 17), and 1x about 6 MOhm (C2 - pin 18) - that’s the O2 heater control for O2 sensor 2/2 - this sensor doesn’t throw a code at the moment - would be P0057).
- With ignition on / engine off, all O2 sensors show 1.27V (Wrangler manual: 5V) - read via OBD. During engine idle, they show 0.04V - 0.06V and increase and decrease while driving (up to 0.9V).
- I swapped the ASD relay against the fog light relay (same spec), the fuse #17 (Power - 20 Amps) is also good.
Do you think that might be the PCM itself?
Reactions: Wranglerfix
it is the pcm failing you. You will also get loss of gauges, usually the fuel gauge and stalling while driving. All of those are the result of Pcm failure.
Doesn't do you much good now but rule #1, Take what the seller says with a grain....er...big bag of salt when it comes to the CEL or easy fixes. There is s reason it was for sale. Im amazed at some of the BS stories Im hearing as I look for another jeep.
Reactions: tr21triton
Update:
I replaced the PCM with one from @Wranglerfix and CEL was off. Obviously the 4 emission tests were "not completed", but after 3 days of driving, finally the "O2 sensor" test switched to complete. Then after another day of driving, the CEL came on again and I got the codes:
- P0133 "Heated oxygen sensor (HO2S) 1, bank 1 - slow response" - confirmed
- P0431 "Warm up catalytic converter, bank 2 - efficiency below threshold" - confirmed
How come that even with a new PCM and 4 new NTK/NGK sensors, the P0133 error code shows up? And is the P0431 an indication of a failing catalytic converter, that just wasn't showing up due to the failing PCM before?
I also found the suction line that goes into the firewall to be fixed poorly, so I fixed it again with shrink tubing yesterday and cleared the codes. CEL is off (due to code clearing), but now I got another code "pending"
- P0457 "evaporative emission (EVAP) system - leak detected (filler cap loose / off)"
The fuel cap is not loose. This TJ is giving me headaches. Anyone some hints / ideas / helpful thoughts?
Edit: I did a video of the O2 sensors at idle - maybe that helps:
