O2 sensor circuit codes
Brokenbenz717
Delaware
Hello all, I just bought a one owner 05 TJ with 90k on it. I have a check engine light on for all 4 sensors. I found the positive signal wire for the starter melted against the block I'm not sure if that has maybe shorted out the PCM I'm hoping you all can help me.
Reactions: Wranglerfix
Faulty O2 sensor readings is the pcm failing on an 05-06 TJ. You can call me to discuss in further detail if you would like.
