On my 1998 TJ Sahara for the past two days I've had intermittent start sometimes. Specifically, I would turn the key and nothing happened for about a two or three second delay and then it would start normally. Today after Church I went to start and nothing at all again but this time it didn't start after the two or three second delay in starting it had previously done on a couple of occasions. It ia a 5 speed so I was able to push start it and get going.
During these episodes normal dash lights, blower motor, ignition dinging and radio all function as typical on start up just no turning over at all.
My question is, is this problem indicative of a failed clock spring, or could it be a failed ignition cylinder on the steering column, or should I turn my attention elsewhere? Any help is very appreciated. Thanks in advance!
