Hey yall! I have a 2005 Jeep wrangler won’t crank won’t start, no noise. Dash lights and headlights come on normally, check engine light is flashing. Was starting perfectly fine prior. I towed to mechanic and they recommended replacing the ignition lock cylinder but they’re not sure that’s the issue. Per what I’ve researched it seems like the ignition switch actuator pin might be the culprit, but the mechanic swears that’s not the problem but also admits they didn’t check the pin, and won’t check the pin. What are y’all’s thoughts?
