No Bus Error: Thanks WranglerTJForum
Ruger656
NE Oklahoma
So I've been lurking on here for the last few weeks as I try to run down No Bus Error. Registered as a member so I could post if needed. After reading lots of threads and learning more about this Jeep the winning advice goes to Rook from a 2018 post. I had checked the obvious (grounds, fuses, battery connections) and then started wringing out wires, checking instrument cluster, ignition switch, and numerous other things. Everything was pointing to no power from ignition switch. Thanks to Rook I went back and checked Fuse 12 behind glove box (which I thought I had already checked twice) and sure as heck it's bad. Simple fuse replacement and I'm back in business. And yes, I know better than to just look at a fuse but we all get wrapped around the axle sometimes.
So, thanks to all at wranglertjforum for guidance. I'll be hanging out here for a while.
