I found it while looking for a solution to the mess created when dropping the filter on a 2021 ram half ton.That looks like udder nonsense, does that actually work for you? The oil leaks down the block. How would it do anything useful if it doesn't seal on the block and even if it did you have to pull it off the block at some point and then you have the same mess.
One of the ways they show using it is puncturing the filter and letting it drain before you loosen it. One might be able to use it on a Jeep. I'm ordering the 4" for the half ton so I guess I'll see if it works on the TJ too...lol
