Just some thoughts: new or old battery, plugged exhaust, are all the grounding wires good ?
Running out of ideas, possibly a bad TPS sensor since it dies when you open the throttle?
I guess we'll find out together later today after I do some testing. The scanner has a live data capability so I guess we're golden.What should I be looking for and what PCM trim mean?
Just checked TPS started .86 ended 4.63 From FSM it's a little high on bottom of the scale Does it pass
This morning I went to start it and it won't Cranks over had 20# fuel pressure when key turned on jumped to 46# while cranking Would a code PO351,2,3 cause a no start condition? What am I missing Last nite it would start n stop n restart w/o any ressitation It ran a little rough but ran
Check the wiring to the coil and the wiring that goes behind the valve cover. Unlikely all 3 coils would die at once.
And timing. Fuel, spark, compression and timing.
I agree with chasing spark especially with wet plugs.
Need an oscilloscope to test Crank and Cam sensors. @hear wrote up how to do it with a $30 Amazon Bluetooth scope. Your scanner might be able to display the wave form.
We've had a couple of folks put Luk flywheels on having issues...I can't recall if they're keyed with the bolt pattern but the gaps in flywheel were in the wrong places for the PCM to get correct timing info. Let me know if you want me to search for that post.
-Mac
-Mac
The PCM controls the ignition timing. Nothing to set. The plugs are fired off the crank sensor in pairs. 1 and 6, 2 and 5, 3 and 4.
The mechanical timing of the cam to the crank can be off if the timing chain is off a tooth.
The cam sensor controls the sequential fuel injector timing.
A new week and a new outcome I hope. Back to my issue and here's where it stands. Took the coil rail off and inserted a spark tester into the boots and got a white spark intermittently around the tester. Found an article on another site regarding testing the coil rail with a ohm meter. So I'm going to try that this am before I run down to buy a new one and test it before installing it. Can you do the same with the Crank sensor and Cam sensor? I know I have fuel, 48# cranking, as the plugs are fuel soaked to the point of replacing them .I have compression by a known good tester. Going to recheck the initial install of the cam sensor/TDC mark. I have a CEL on, dash gauges work except tach when trying to start. I found that my new SMP crank sensor was to short to have the spacer wore off by the crank so I made my own .030 spacer and installed the one that came out of the old motor. Again this was purchased as a non run vehicle with no history other than a hole in the motor where one was not to be. I know I have to have fuel, compression, and spark to make it run. Am I going down the right path in a proper sequence or am I just running in circles? Thank you all for your insight and suggestions.
