Pritchett. I suggest splitting that up a bit more, perhaps setting up a separate start time for each group - maybe separated by an hour or two. Even with the proposed “first group takes off after finishing the obstacle” approach, the problem with Pritchett is that since the obstacles are so close to each other, this will still wind up like trying to run it with 15 trucks.
My two cents. Interested in what others think, so please chime in.
Pritchett always seems to invite some issue that makes it take a lot longer to complete it than it should.
There's just as good of a chance that the second group never sees the first group after a couple obstacles as there is that the second group needs to pass the first group because someone had an issue that needs to be fixed such as a tire or ujoint.
However, if some prefer to sleep in and start later then it's always an option.
