2005 ljr manual. i learned (probably here) that the mfsw connector melts and blows the underhood 20a mfsw fuse. sure enough mine was melted, but after replacing the connector the fuse still blows as soon as i insert it. with the connector disconnected from the mfsw the fuse is fine.
so i guess i'm replacing the multi switch unless someone knows something else i should check first.
thanks!
thanks!
