I actually wish I could do an emissions legal Magnum swap. With my 04 though, I need to use a hemi from an 04 or 05. Any later, and the bus changes.
I guess there are two ways to look at this. It's easier for you to swap a Hemi than it is for the pre-2000 TJ folks.
All this is from Hotwire Auto.com
For anyone wanting to know here is the Mopar Swap Grid.
MOPAR Swap Grid
We've developed the charts below to help in the decision process when looking at LATE model Mopar engine swaps.
Review the list below to find your vehicle and check the computer bus to find matching donor vehicles. The easiest swaps are accomplished by using the same computer bus.
Protocol List By Vehicle:
| Ram | Durango | |||||
| Year | Bus | Engines | Year | Bus | Engines | |
| 1996 | CCD | 3.9L, 5.2L, 5.9L | ||||
| 1997 | CCD | 3.9L, 5.2L, 5.9L | ||||
| 1998 | CCD | 3.9L, 5.2L, 5.9L | 1998 | CCD | 3.9L, 5.2L, 5.9L | |
| 1999 | CCD | 3.9L, 5.2L, 5.9L | 1999 | CCD | 3.9L, 5.2L, 5.9L | |
| 2000 | CCD | 3.9L, 5.2L, 5.9L | 2000 | CCD | 4.7L, 5.2L, 5.9L | |
| 2001 | CCD | 3.9L, 5.2L, 5.9L | 2001 | PCI | 4.7L, 5.9L | |
| 2002 | PCI | 3.7L, 4.7L, 5.9L | 2002 | PCI | 4.7L, 5.9L | |
| 2003 | PCI | 3.7L, 4.7L, 5.7L, 5.9L | 2003 | PCI | 4.7L, 5.9L | |
| 2004 | PCI | 3.7L, 4.7L, 5.7L | 2004 | CAN | 3.7L, 4.7L, 5.7L | |
| 2005 | PCI | 3.7L, 4.7L, 5.7L, 8.3L | 2005 | CAN | 3.7L, 4.7L, 5.7L | |
| 2006 | CAN | 3.7L, 4.7L, 5.7L, 8.3L | 2006 | CAN | 3.7L, 4.7L, 5.7L | |
| 2007 | CAN | 3.7L, 4.7L, 5.7L | 2007 | CAN | 3.7L, 4.7L, 5.7L | |
| 2008 | CAN | 3.7L, 4.7L, 5.7L | 2008 | CAN | 3.7L, 4.7L, 5.7L | |
| 2009 | CAN | 3.7L, 4.7L, 5.7L | 2009 | CAN | 3.7L, 4.7L, 5.7L |
| Dakota | Wrangler | |||||
| 1996 | CCD | 2.5L, 3.9L, 5.2L | 1996 | |||
| 1997 | CCD | 2.5L, 3.9L, 5.2L | 1997 | CCD | 2.5L, 4.0L | |
| 1998 | CCD | 2.5L, 3.9L, 5.2L, 5.9L | 1998 | CCD | 2.5L, 4.0L | |
| 1999 | CCD | 2.5L, 3.9L, 5.2L, 5.9L | 1999 | CCD | 2.5L, 4.0L | |
| 2000 | CCD | 2.5L, 3.9L, 4.7L, 5.9L | 2000 | CCD | 2.5L, 4.0L | |
| 2001 | PCI | 2.5L, 3.9L, 4.7L, 5.9L | 2001 | PCI | 2.5L, 4.0L | |
| 2002 | PCI | 2.5L, 3.9L, 4.7L, 5.9L | 2002 | PCI | 2.5L, 4.0L | |
| 2003 | PCI | 3.9L, 4.7L, 5.9L | 2003 | PCI | 2.4L, 4.0L | |
| 2004 | PCI | 3.7L, 4.7L | 2004 | PCI | 2.4L, 4.0L | |
| 2005 | CAN | 3.7L, 4.7L | 2005 | PCI | 2.4L, 4.0L | |
| 2006 | CAN | 3.7L, 4.7L | 2006 | PCI | 2.4L, 4.0L | |
| 2007 | CAN | 3.7L, 4.7L | 2007 | CAN | 3.8L | |
| 2008 | CAN | 3.7L, 4.7L | 2008 | CAN | 3.8L | |
| 2009 | CAN | 3.7L, 4.7L | 2009 | CAN | 3.8L | |
| Grand Cherokee | Cherokee | |||||
| 1996 | CCD | 4.0L, 5.2L | 1996 | CCD | 2.5L, 4.0L | |
| 1997 | CCD | 4.0L, 5.2L, 5.9L | 1997 | CCD | 2.5L, 4.0L | |
| 1998 | CCD | 4.0L, 5.2L, 5.9L | 1998 | CCD | 2.5L, 4.0L | |
| 1999 | PCI | 4.0L, 4.7L | 1999 | CCD | 2.5L, 4.0L | |
| 2000 | PCI | 4.0L, 4.7L | 2000 | CCD | 2.5L, 4.0L | |
| 2001 | PCI | 4.0L, 4.7L | 2001 | CCD | 4.0L | |
| 2002 | PCI | 4.0L, 4.7L | ||||
| 2003 | PCI | 4.0L, 4.7L | ||||
| 2004 | PCI | 4.0L, 4.7L | ||||
| 2005 | CAN | 3.7L, 4.7L, 5.7L | ||||
| 2006 | CAN | 3.7L, 4.7L, 5.7L, 6.1L | ||||
| 2007 | CAN | 3.7L, 4.7L, 5.7L, 6.1L |
And then for anyone wondering what their prices are:
TJ Conversion Harness Prices
| ITEM | PART NUMBER | PRICE |
| 5.7L HEMI / 545RFE Automatic Jeep TJ Conv 2001-2006 | R-0025 | $1,885.00 |
| 5.7L HEMI Manual Jeep TJ Conversion 2001-2006 | R-0025-1 | $1,885.00 |
| 5.7L HEMI / 545RFE Automatic Jeep TJ Conv 1997-2000 | R-0025-2 | $2,035.00 |
| 5.7L HEMI Manual Jeep TJ Conversion 1997-2000 | R-0025-3 | $2,035.00 |
| 6.1L HEMI / 545RFE Automatic Jeep TJ Conv 2001-2006 | R-0025-4 | $1,885.00 |
| 6.1L HEMI Manual Jeep TJ Conversion 2001-2006 | R-0025-5 | $1,885.00 |
| 6.1L HEMI Automatic Jeep TJ Conversion 1997-2000 | R-0025-6 | $2,035.00 |
| 6.1L HEMI Manual Jeep TJ Conversion 1997-2000 | R-0025-7 | $2,035.00 |
| 5.2L/5.9L Dodge Magnum Automatic Jeep TJ Conversion | R-0029-2 | $1,615.00 |
| 5.2L/5.9L Dodge Magnum Manual Jeep TJ Conversion | R-0029-3 | $1,615.00 |
| 1997 & Up Dodge Viper V10 Jeep TJ Conversion | R-0031-2 | $1,755.00 |
Computers, Accessories & More
We have computers and computer re-programming available to make your Jeep project complete. We also carry a number of accessories such as motor mounts and radiators to make your install go smoothly. Please contact us for a complete list of items and pricing.
Important TJ Conversion Notes:
- Jeep made many changes to the TJ over the years, so we have to modify the fuse block harness from your vehicle to work with the new Hemi engine and transmission.
- Remove the fuse block harness from your TJ. The fuse block is located on the front right fender well. Unplug all connectors as close to the fuse block harness as possible and remove the battery cables.
- DO NOT CUT ANY WIRES!
- You will need to send us the Fuse Block harness from your TJ for modification.
Send to:
Squier Inc.
256 Polk Rd. 43
Mena, AR 71953
- When you get the conversion back from us, re-install the fuse block harness to it's original location.
- Lay the new Hemi engine harness over the engine with the trunk of the harness sitting just behind and below the right side fuel rail.
- For 6.1L Hemi motors you will need to remove the intake to route the harness. The main sensor branch with A/C Compressor, Engine Temp, Oil Press, Throttle body, etc will lay under the intake.
- Locate the Driver and Passenger side items and route them around the intake to the correct locations and plug them in.
- Mount the Hemi computer in the factory location and plug in all the connectors.
- Installation of the wiring is pretty much complete at this point but there are some additional items that you may need to address depending on the year of your TJ.
- 1997-2000 TJ’s - You will need to upgrade your instrument cluster. We provide all the information you need to make this swap.
- Pre 2005 TJ’s - You will have to upgrade to the 2005-2006 fuel pump module. A complete 2005-2006 fuel tank and NVLD system upgrade is required for a working check engine light.
- Various Year TJ’s - Some will have to add sensors such as: Battery Temp, Ambient Air Temp, etc.
- You may have an orange open wire under the dash labeled "Overdrive Off Switch". You can hook this wire up through a momentary switch to a ground if you want to be able to disable the overdrive.
- Some older systems will have 2 open wires you need to hook in to your factory brake light switch. These wires will be labeled if they are there.
- 52059627AB - Bracket, Vapor Canister
- 52059630AB - Canister, Vapor
- 04891564AB - Filter, Leak Det Pump Base
- 04891427AB - Detector, Natural Vacuum Leak Detection
- 52059628AA - Hose, Canister to NVLD
- 52059633AB - Hose, NVLD to Filter
