Yes, sorry, I meant buy a JL 392 and sell my TJ, not swap in a 392. ...
Ok - Now that's even worse...
It sounds to me like you've kinda made up your mind about a 392. For you , this may be a path forward . Since you're comparing the " ride " of a TJ to a 4 dr. JL
I feel you won't be happy with a TJ modded to perform with a 392 in every aspect. I hope you find what will work for you .
You aren't wrong, I think I'm unfortunately spoiled as my daily driver is a yukon xl denali so the difference between that driving experience and the TJ is fairly harsh. Driving my TJ this morning reminds me why I still think about spending money on it, I have built this rig myself and have a lot of pride with it, something about buying a 392 makes me wonder if I'll feel like a sell out.
What do you mean, the pump or regulator or a clog in the line?
I understand that, our two other vehicles are a 2020 Lariat Super Duty and a Yukon Denali, both with ventilated seats and the whole nine yards. Yet I still drive the LJ to work more days than not on a 30 minute highway speed commute.
Making sure the suspension and steering are tight and your geometry isn’t messed up from a half ass lift adds as much or more to the driving experience than the LS does.
I love driving my LJ, but I also took the time to make sure everything worked with the LS. Cruise, A/C, etc. I can cruise down the interstate at 80mph plus with one finger on the wheel and the cruise set. It drives great up to 90 but then I start getting a little rear driveline vibe since I’m running a shortened LJ stock shaft and haven’t upgraded to the CV yet. Not that I need to go any faster anyways.
When not running the hard top, noise cancelling ear buds are also a game changer. I learned a long time ago with driving jeeps and motorcycles across country, wind noise not only contributes to hearing damage, but fatigue as well. Ear plugs or noise cancelling buds are a must in my book.
Doesn't feel dangerous to you to drive with headphones in? I can never bring myself to do it
Start by checking the fuel pressure at the fuel rail. You should have between 58 and 62 psi. I see you have an 04. Did you change the fuel pump or add the Novak regulator that is supposed to remove any regulation on the pump side?
I used the regulator from Novak, I’m going to have a shop tune the rig next week and I’ll have them check the psi while I’m there, thank you for the suggestion.
This is my 5.3 4L60E combo. 33's and 3.73 gearing, 3000 stall, mild tune, stock everything.
Link below skips to the dead stop acceleration. This was before I installed the correct speedo gear, so the MPH indicates about 5mph slow.
Helpful thank you, I’m running stock stall which I think is around 1700, I was nervous messing with that before I got everything up and running, how do you like the 3000?
Illegal here
Illegal here
Same here.... Never have liked not being able to hear stuff when driving but then again I've got hearing lose now due to all the stuff I'd done in the past.
The wind/noise fatigue is real! My daughter demands top off and half doors which I can appreciate, I’ll have to try my AirPod pros next time I cruise. I know Novak sells an emulator that works with the cruise control but I haven’t wanted to go through the wiring after I’ve already loomed up the prior work but if I get the suspension and engine dialed in I probably will get that to work. I currently have an ac leak so it’s something I need to have fixed.
