So correct me if I'm wrong but in the long run, this will have to be done at some point unless someone uses my LJ as a donor or parts Jeep, right?
I am of the opinion that if I can be the owner to do it, why not? Also by doing it, I understand I will never "make money" on a Jeep but with a clean frame swap that was done right is worth more than one with a frame that will need to be replaced at some point, correct?
I mean, what's the going rate for a 131K mile LJ with a 4" lift, 35s, all new steering components, hubs, and brakes that needs a frame swap at some point?
And to clarify, the frame is not falling apart right now. There are a couple of smaller holes and it has been patched in one place before but it's not "tweaking" with on-road driving and it's not creaking/folding/falling apart on the two post lift. The timeframe we set for this project is just before next Spring/Summer when we will really be using the Jeep, provided we can find a good frame.
If you are able, post some photos of the frame in this thread. Might end up being a roast if it’s really bad, but odds are we (this forum) can give some perspective on what to look out for.
Some things might be more repairable than you might think.
