JKS quicker disconnect issue
Ahhh. Thank you! I thought the bolt was welded to the bracket and just the nut was separate. This makes much more sense :). Thank you both!
Pictures are worth a thousand words. I can't remember who's quote that is? Either Gandhi or Ron Burgundy.
I don't have these specific disconnects, and am usually pretty good at visualization, but from the picture am having a really hard time understanding how that QD bracket would attach on top of the sway bar without interference. I looked at a couple videos and threads and they all seem to have them installed the same as DaveC.
It certainly isn't critical, but can you sort me out on this? We're talking about the C bracket that is attached to the sway bar itself and that is presently sitting under the swaybar, correct? And you are suggesting that that bracket should be on top of the sway bar with the nut on the underside? Or am I completely misunderstanding your post?
Doug
Reviving an old thread as I ran into something similar this week.
The links should be adjusted so that the load on the swaybar is neutral when the jeep is at rest (unloaded).
I spoke with Dirk at DPG Offroad this morning. I don't think there's a more knowledgeable person on JKS' product line, and he confirmed this sentiment.
Something else to note, depending on what coils you run, a minor sag on the passenger is considered normal. For example, I run OME coils, and the driver side coil is roughly 10mm taller to account for the drivers weight (passenger side rear coil has the same 10mm offset to account for drivetrain torque).
When installing my quick disco's, my passenger side disco is .25" - .50" shorter (adjusted in freedom units) which roughly equates to the 10mm difference in coil height. Again, all normal and by design (certainly for OME coils).
