And boom! Installed on the stiffest setting. Need to do some flex testing before I take it out on the trails, but looking forward to getting it out there.
Looks good and like it arrived intact. I guess my packaging worked?
It did indeed! It was packed perfectlyLooks good and like it arrived intact. I guess my packaging worked?
I was really interested in it too. I figured that most people didn't use it which is why they dropped the front two on the new versions, but I wanted first hand experience as to why. I'll report back once I get a chance to test it out.I'm curious to hear how you like it on the tightest setting. I've never tried to run it on that setting. The most I ever tried was the middle when they came with 5 holes.
I did use it on the stiffest setting before and liked how it drive in the street. Off-road I thought it was a little limiting, which is why I moved it to the middle setting. The middle was my compromise, better of both so to speak. You can see the hole locations on the arms where I used it.I was really interested in it too. I figured that most people didn't use it which is why they dropped the front two on the new versions, but I wanted first hand experience as to why. I'll report back once I get a chance to test it out.
A subtle detail, but so beneficial. Great looking JeepI stopped by Harbor Freight today and picked up some rotary rasps. I took the evening to round off all my recovery points. I finished them off with some 150 grit. All that’s left is some paint.
Thanks! Now that I’ve got a garage I’m trying to work on all the finer detailsA subtle detail, but so beneficial. Great looking Jeep
Ripping your newly made soft shackle would suck a big one! Good idea. Got any finished pics of the shackle? I still haven't made the switch from the old steel ones.I stopped by Harbor Freight today and picked up some rotary rasps. I took the evening to round off all my recovery points. I finished them off with some 150 grit. All that’s left is some paint.
I have some pics from when I was burying the tail. If you want to come by one weekend we can round yours off for when you make the switchRipping your newly made soft shackle would suck a big one! Good idea. Got any finished pics of the shackle? I still haven't made the switch from the old steel ones.
I just hopped over and read thru your brake issue you were having. Did that ever iron out? I really like the idea of running a single line into a Tee for the front brakes. (Just like the factory rears)I've been working through some brake issues over in this thread. I bought some new tools over the weekend to help with the bleeding process.
I re-bled the system and it was a lot better, but I'm still dealing with a bit of a hold on release from time to time. I need to do one more bleed and if that doesn't fix it I'm going to pull the lines and check for a blockage somewhere in them.I just hopped over and read thru your brake issue you were having. Did that ever iron out? I really like the idea of running a single line into a Tee for the front brakes. (Just like the factory rears)
