awesome. so I have that to look forward to...![]()
Metalcloak isn't a favorite among some members but I doubt you'll have any problems.
I've picked up on some of that in other areas of the forum. It seems MC's reputation has taken a hit since I first used them years ago. Is there a good reason behind it? Or is it just talk?
I went with a ton of their products because I like the way they look, and fit. I've not had a problem yet with a single order (aside from my first set of fenders rusting prematurely, which MC took back and refinished for me for free).
I've got a lot of MC on my blue jeep. It seems to get me where I want to go and there are some things I like about their stuff that nobody else offers.
Nothing wrong with their products just SOME don't like the look & because of their marketing they are frowned on. But the good thing is that a few of us (more than a few) have MC stuff on our rigs.
You Jeep is LOOKING great. Keep it up & good work BTW.
This has been kind of nagging at me since my jeep came home. Have any of you use the MC corner guards and run into this little 'problem'? The tub hangs down a little, and I'm wondering if that will be a clearance issue that they compensated for with 35" tires. What have you guys done to resolve this? The way I see it, I have a couple of options.
1) leave it, paint it black, and throw the fenders on.
2) cut it flush with the corner guard, paint it black.
Thoughts?
Thoughts?
That’s where 35’s hit, most trim that off.
Nice work. Is there any reinforcement to the passenger side body where the carrier mounts?
I think the reinforcement is the corner guards. They are pretty clear in the instructions that these carriers are not designed to be mounted directly to the tub. Corner guards are required. But to answer your question, there is not any additional support.
With that big tire back there, it may be worth adding some support to the upper bracket inside the tub. Years ago I ran an ORO carrier with a similar mount. It came with a bracket which bolted to the roll bar mount and reinforced the back side of the tub, using the through bolts from the top mount.
You may be OK as perhaps the steel corner guards might provide enough support. If it were me - with the way I bang on my rig - I think I'd add something there.
Great work. I'm enjoying following along.
I just spent probably way too much time trying to research and find that carrier to see if I could order the bracket separate, to no avail. I do like the idea of tying in the tire carrier to the roll bar. I think it will require fabrication work that may be a touch over my head. lol I'll keep searching for a solution.
Thanks for the tip!
Here is what Rusty's brace looks like.
There are other companies that made these braces too.
That seems a lot more doable to me. I was picturing a clamp around the bar...
another thought that just occurred to me on this topic, is that because the MC tire carrier is mounted to the corner of the tub and not the edge of the tailgate opening, I feel like the structural support would already naturally be much stronger. Due, of course to the curved steel. Makes me wonder if I can get away with leaving it.
Although, seeing the picture above, I feel fairly certain I could just fabricate that mount relatively easily...
