Is this a 4.0 engine?
Not gonna happen. If you see any of my stuff and pay attention to it for any length of time you will note fairly quickly that I am of the mind that it is far better to teach someone who is hungry to fish than to share your lunch with them every day.
I would much rather poke and prod a bit to give folks a way to use their intelligence and develop critical thinking skills to solve problems on their own than just give them a single answer.
He learns nary a fucking thing beyond knowing that he has a 4.0 if you say, Yep, that's a 4.0. If you get him to understand that a 4.0 is also a 6 cylinder and there are several ways to determine that, then now he has something of value. He also may want to change his plugs one day, how will he ever know how many to buy if someone doesn't point out that he can see them? He just needs to know where to look. Knowing it is a 4.0 won't help him find them.
I agree lets teach and learn from each other. Knowledge transfer is a great thing, but you make the assumption that he knows what all those things are that you stated. One engine is a 4cyl and the other is 6, easy to know the difference if you know what you are looking for. If he knew, he would not asked the question he did. In this case you were making an assumption. Not everyone has the knowledge that many do on this forum and that's why they come here. I do read most posts you make. You have a great deal of knowledge but there is no need to be so pompous in every post.
Reactions: chad
I know you think you are chastising him, but you are arguing in favor of the very thing you are criticising. All that happened was that the hand holding was cut short. Don't assume the OP doesn't know what an injector is or can't look it up now that it's existence has been suggested.
I'm still curious what the other items were that the seller lied about that cost the OP so much money...
I saw fresh oil underneath but I'm not sophisticated enough to tell where it came from. Also the clutch made a grinding noise. When I heard this I said not interested and walked away.
He texted me later and said he would take it to a mechanic. Three days later he said that four mechanics drove it and it didn't make the grinding noise. I met him later and went on another test drive. All good. He leaves and on way home it started again.
Took it to a mechanic and clutch is and and RMS needed to be replaced due to the leak. He said no oil on his garage floor.
I was excited and wanted the Jeep. I don't regret buying it but am kicking myself for not being wiser. Never bought anything from Craigslist before and this will be the last.
Part of it is my fault for being naive and trusting.
It's happened to the best of us. Don't let it deter you from enjoying the hell out of your TJ.
Reactions: jjvw
Just curious what gear did it grind in? was it reverse by any chance?
1st. When I pressed in the clutch. Mechanic said it was a spring or something in the clutch. Hopefully this will be the last clutch I will have to install
ok i thought you were referencing putting the jeep in reverse because if that were the case i would tell you its normal, but its not normal in 1st.
That was worded badly. Needed new clutch and RMS.
Unfortunately you will need to get used to the RMS leak. That seems to be chronic on these Jeeps. Your mechanic fixed it with the new RMS seal, but it will be back, oh yes, it will be back.
On the bright side you can tell how dirty your oil is without pulling the dipstick. When my RMS leak is black I know to change the oil. When my RMS stops leaking I know I need to replace the RMS seal because it is leaking too much and drained the pan.
Reactions: primetime4
You may need a new mechanic. That sound when the clutch is pressed in is pretty normal. Most likely a transmission input shaft noise. Mine has made that noise for years. That noise and an RMS leak is what makes a TJ a TJ. Even if you replace the RMS, chances are it will start leaking again in no time.
Sucks you have encountered this on your first CL purchase. Craigs is a great place to find used parts at good prices. Been lucky to find some good Jeepers buy or selling parts.
I made no assumptions. Had he come back with "what is a fuel injector?, how do I read English to translate the label on the hood", where is the intake", where is the exhaust?, then those would have been explained in enough detail for him to learn what they are. You only think I'm pompous because I hurt your feelings at some point.
Reactions: Ericict
Don't feel too poorly over the RMS. You have about a 50/50 chance that it will leak and I'm being kind. If you had me take it to 4 mechanics, it would cost you about a day of my time because I live in a mechanic poor environment and even then I'm not sure I could hit up four in one day.
I had a 1995 Jeep Cherokee that had a leaking rear main seal the whole time I owned it; over 170,000 miles driven by me. It only leaked a couple of drops and it still leaked when I sold it. If you just have a few drops you can live with it. If you have a small puddle, you'll need to replace it or live with it by constantly topping off your oil to account for the loss.
Sorry to hear about your problems. I felt the same way after getting mine home and starting to clean it up. I am pretty sure the seller pieced my jeep together from parts, because I am finding things from multiple years all over it and lots of things broken that he said were working perfectly.
For example the A/C blew cold as ice when I bought it, but after 2 weeks was dead. I was pretty annoyed and have attempted to fix it, but it still leaks slowly. Also, the valve valve cover gasket leaked like crazy, but was pretty clean on initial inspection. He had obviously cleaned it up before I looked at it . Unfortunately the list goes on. It is ultimately my fault because I did not inspect it close enough, but it was my 1st Jeep and I honestly just got excited and caught up in the purchase. He seemed like a nice guy too.......
On the bright side, these things are pretty simple to work on, and fit together like the automobile version of Legos, so having parts from multiple years is not a huge deal. This forum was a huge help and has really knowledgeable people who are willing to help, so take advantage of their knowledge for sure. Just get it to running/driving order and once you are a few months past the hurt from the lies you will love it and the little problems will not seem like such a big thing. Just take your time and fix them as you go.
Hey don't feel bad.
I have had seven Jeeps but my TJ is the first one I've purchased in 25 years.
I paid over $20,000 for a low mileage Rubicon, and nearly twisted my arm out of socket patting myself on the back.
2 regears , 4 tires , windows , fluids , u joints , unit bearings, a new crappy lift to replace the crappier lift , shocks , and tons of this and that...
Now I've got a pretty nice TJ, most guys on here would have 2-3 for what I spent .
Some of it was just getting excited and not paying attention to the aged condition of the vehicle.
Some of it was ignorance, not knowing what to look for.
And some of it was getting all excited over big fat tires and the look of it ...
I didn't make the right decision but at the end of the day I tried to make the decision right.
Anyway enough with my stupidity... If the thing's not rusted out, and if you didn't pay a ridiculous price, it's probably going to work out pretty good and you can just about bet it's going to be a ball.
Sometimes we give Jeeps a bad rap.... Show me any vehicle that's designed for off-road use and is 13-22 years old ... Most likely that vehicle is going to need some work.
The 4.0 was chosen for the Tj probably because they had the tooling and production set up , it works good in it , and the market loved that engine .
It is long way from today's engines, but it's tough and reliable.
Hang in there and stay on here and work the bugs out of it ..you may find it to be one of the favorite vehicles you've ever owned.
Reactions: gbirk
