Installing Yukon WU-08 Hub Kit (Similar to WU-07 Also)
I have revolution gear chromoly axle shafts. These Yukon kits come with the outer shafts. Am I able to retain my current RGA shafts or does this kit require they be swapped with the ones in the kit?
To clarify, if you have Revolution import inners and outers, you will swap the stub shafts from the Yukon kit onto your inners. If you have the US big u-joint shafts from Revolution, then you will need to acquire inners to work with the 5-760x joints that the Yukon stub shafts fit.
Reactions: Gollywomper
That was an important detail, thank you.
I do have US big u-joint from revolution. This project turned spendy fast. Maybe I'll just deal with the vibes. Its been 5 years dealing with them already. I'm sure I'm accelerating the end of life of components by not doing something.
Reactions: mrblaine
