I've got a curious problem. On my 2006 Wrangler TJ, I can insert the key and turn it clockwise to start the car, and everything seems to be fine. When I turn off the car, I can only rotate it counterclockwise 1 click, which turns off the car fine, and I can remove the key. But I cannot rotate it further to set the steering wheel lock, or to the position where it just activates the electrical system.
I had a similar problem a couple of years ago, where the lock was completely stuck in the position just before I could start the engine. That turned out to be a broken ignition pin in the lock. This seems different. The car is drivable, but should I put in a new lock? Is there a danger that the lock will go completely bad and strand me somewhere in the middle of nowhere?
