joestewart
Fuse, excellent write up.
In your first post, you stated "the compressor piston has a direct connection to the motor, so it runs even when you're just using the winch."
I would like to DISABLE the air compressor section of my Powerplant 12k, such that the motor will no longer waste power in turning the compressor's crankshaft (my powerplant will become a "winch only").
Since you have had yours apart, I figured you would be a good person to ask.
What would be the best way to disengage the motor from the air compressor section of the Powerplant?
Many apologies for the dumb question. I suppose I just need to dismantle mine and figure it out. Thanks!
