High speed shaft balancing
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Who has had high speed shaft balancing done and how did it work.
I have a vibe around 60- feels driveline generated with George’s 5:38 gears.
Ready to dial in this rig.
Thanks
Andy
Had both mine balanced at a local shop, not sure if it was high speed or low speed. I don't think it matters unless something is wrong where your shaft is deflecting at higher speeds. Otherwise imbalance is a linear relationship and balanced at 1500rpm is balanced at 3000rpm as a practical matter.
Thank you
Thanks
Andy
Denny's Driveshaft advertises high speed balancing. I believe 5.13/5.38 would need about 6,000 rpm.
https://www.dennysdriveshaft.com/c4_4x4_driveshafts.html
"BALANCE:
ALL DENNY'S DRIVESHAFTS are HIGH SPEED - HIGH RPM BALANCED and TESTED to be sure each driveshaft will run smoothly at your full rpm range and at all road speeds. Our equipment can balance and test your driveshaft to 10,000 rpm. This is priceless when it comes to customer satisfaction."
