Hey great. I will start there and see what happens. Thanks againNo. If you can handle a phillips head screwdriver, you can replace that switch in under 5 minutes. Remove the plastic protective clamshells that surround the steering column by removing the two screws in the bottom cover. The switch is only held on by a couple more phillips head screws. It just plugs in.
