Help With LED Kitchen Hood Light
Plumber1
Tito's, Tacos and Trails
San Ramon, CA
My existing florescent light has become dull so I removed it and bought a replacement LED tube. Installed it and it will not light up, thought maybe it was defective so I took it back and got another one. Installed and the same thing it will not light up, so I reinstalled my old florescent light and it comes on so I know it is not a power issue. The new one is just a hair shorter than the old one is this enough to make it not work or should I be looking at something else ??
As 101 stated there are 2 types of LED retrofit tubes, type A which works with your existing ballast or type B where you bypass the ballast. The pin length is fine as the contacts are not in the end of the tombstones but in the curved recesses where the pins twist in.
Reactions: Zorba and 1o1proof
So why don't they work when installed ?? when the old one does :unsure:
Since that LED requires a ballast, are you sure that your original problem wasn't the ballast being worn out, rather than the bulb? You may need to replace the ballast.
And your old tube was a T-8, not a T-12 right? What about a starter? If you have a starter the LED will not light unless you insert an LED starter, which is basically a jumper, meaning you can also just wire around the starter to eliminate it.
edit: I see in the pic your old one is a T-8. The only thing I can think of is your old one uses a magnetic ballast and starter, if so the starter needs to be removed and the socket shorted either by cutting and splicing the wires or inserting a LED starter. If that's not it I don't know what to advise except trying a different brand.
If you have an electronic ballast it should work, there is no starter with an e-ballast.
If possible it's always better to go with direct wire (type b) and wire around the ballast. Then you never have to worry about ballast failures.
Reactions: Zorba and sab
He posted a picture of the ends of the old and new bulbs in the first post. From that, you can tell it’s not a T8 vs. T12 mismatch.
Reactions: B1Toad
Yep I remembered that and edited my post while you were typing. It's early here :rolleyes:
Reactions: sab
There is not much room to be doing re-wiring. Is the starter what I see in picture #3
Yes that's it! Push it in and twist, it will come out. Then replace with an LED "dummy" starter if it's too hard to open the fixture and bypass. It's possible the new LED tube is damaged from trying to use it with the fluorescent starter.
