But I’d also love for us to get these corrections actually into the relevant sections of the doc.
Do you mean making each of these changes in each of the FSMs (97–06) that we have available for download?
30 lbs may be based on the differential material, not the bolt. They are very easy to strip out with too many ugga duggas.Do we consider the diff cover bolt torque spec of 30lb-ft (p3-144 and 3-152) to be an error? From what I can tell they are 5/16" bolts and my Fastenal chart doesn't show any 5/16" hex head of any grade or thread pitch rated for that, with ASTM A574 fine thread, socket head cap screws being the lone exception.
If I'm wrong about this please let me know, and why.
I think that’s what I’m saying.
Ok well I called Denny's driveshaft this morning to ask about the recommended torque spec. They say it should be 55 ft lbs, so I think that is what I'm going to go with along with red loctite.
Recently, while installing an Atlas transfer case in my LJ, I discovered that the FSM has the wrong resistance values in the chart for the Rubicon NP241 transfer case's position sensor. I was told this by Advance Adapters, but I didn't just take their word for it, I put an ohmmeter on my NP241's switch and ran through the gears. Below is the corrected chart, which can be found wrong in all three Rubicon model year FSMs, on the following pages:
Corrected chart:
- In the 2004 FSM, the chart is found on page 21-263 (pdf page 1413)
- In the 2005 FSM, the chart is found on page 21-231 (pdf page 1375)
- In the 2006 FSM, the chart is found on page 21-242 (pdf page 1432)
I have a short video on my iPhone showing the values as I shift the case with a pliers, but I don't have a way to post it, and I'm not interested in learning that new trick. If you want that for proof, @Chris, I could text it to you. I wouldn't be offended - I couldn't believe Jeep would screw that up so badly.
This isn't the first time something has been wrong in the FSM believe it or not.
If there are enough mistakes, we could devote a thread to the corrections.
Dry humor, or were you not aware of the thread title?
The entire thread was my original concept, I'm post #2 after Chris created it.
That's an odd one. They show the heater control (no A/C option) and the A/C heater control (A/C option) on the same page, with both controls (A/C option and no A/C Option) shown and connected to each other. Huh?I don't know if it's a mistake, but why doesn't the 2006 fsm show the Blower Resistor wiring like the 2005? It's completely different and doesn't match what i have on my jeep.
Does your 2006 wiring match the 2005 FSM pages?
