Flex head torque wrenches
MountaineerTom
LJ Enthusiast, Retired USAF Weapons Loader
Sumter, SC
What are your thoughts on flex head torque wrenches? I’ve always thought you wouldn’t get an accurate reading unless it was static, or in a straight line.
No clue as all I own are fixed head ones.
Like you I don't know hiw well they would work.
Quick google
Does flex head affect torque?
The flex will affect the torque, but, at fifteen degrees, probably no more than 5%. Take the extreme case, when the flex angle is 90 degrees. All the force applied to the handle will be used to 'bend' the stud you are tightening a nut onto, none of the force will be applied as torque to turn the nut.
Reactions: MountaineerTom
I have two. 1/2” and 3/8”. Both snap on not that it really matters as there are other brands as well. The don’t flex like a flex head ratchet. Just a little flex. The don’t flex 90*. I have always found them to be very handy. Seems like I may have noticed some at harbor freight like in their icon brand.
I have these and I think they’re great:
https://www.tekton.com/3-8-1-2-inch-drive-split-beam-torque-wrench-set-trq99902
The flex has helped multiple times, most recently on my kid’s Accord starter. Made the difference between using a torque wrench at all and just going 34 ft. lbs by feel.
I ended up getting an ICON 3/8” flex head torque wrench. The amount of flex isn’t much after seeing it. Less than what I imagined in my mind. It’s already come in handy torquing the belt tensioner bolt and working around the fan shroud.
