Exhaust Troubles
03RubiGold
Alamosa
Good evening,
I can not get the last bolt out of the exhaust manifold for the down pipe. 0² sensors came out easily. The speed nut just doesn't wanna let go. Any help would be appreciated. It's the one furthest to the rear.
What methods have you tried? Penetrating oil? Heat?
I've hit with the ole PB Blastet, gonna let it sit over night and try again after work. I don't have a heat source. Imma ask around the neighborhood network and see what I can come up with. Pics attached
Buy a Mapp gas torch from Home Depot. Put some heat on the nut.
That's exactly what I use. It's normally by the plumbing tools because they're used to sweat copper. MAP's the yellow cylinder and it's hotter than the propane (blue) cylinders.
Always my plan B!! Access is the problem.
Pull the fender off. Thirteen bolts is all that holds it on and makes it soooooo easy to get it done. It’ll take less time pulling the fender and putting it back on than all the time your spending in the struggle. Ask me how I know.
