Sound is coming from somewhere between center console and front passenger area. Can hear it best about halfway through the video when I push the clutch in and coast.
I can’t hear it at low speeds, but as soon as I get around 20 it’s loud enough to hear. It’s consistent with wheel speed, not RPMs. I can put the Jeep in neutral and roll and still hear it. Louder with more speed, quieter with less speed until it’s quiet enough not to hear below 20ish. At first I thought it was going to be my dust shield rubbing the rotor or something. That’s not it. Sound is consistent whether clutch is engaged or not.
Recent work is both new front axles, drained and filled with Valvoline Conventional 80W-90 and full swap back to stock suspension all components, with ZJ steering components. Driveability seems fine, nothing feels off. I’m hoping someone hears it and has experienced it and knows what it is. I’m fearing something wrong with the front diff or wheel bearing but idk what it could be everything went together very well. Checked the fluid, it is full. Ran a small telescoping magnet through the fill plug hole and swiped it around in the fluid. Pulled a VERY small amount of glitter out but nothing big and it wasn’t a lot.
