Alright, first I wanted to thank everyone for their help on my start/idle issues. I spent an hour today testing the camshaft sensor and crankshaft sensor. I then replaced the OPDA, which I plan to do since it was original.
When I started the car again, it was running worse than before, so I loosen the bolt and twisted it. With a little bit of tweaking, I found the sweet spot and the car runs perfectly again. Apparently it was the OPDA all along. My brother must have hit it when we were performing the MML. Again thanks for everyone’s help.
apparently the car runs better with the crank position sensor unplugged then when it’s plugged in.
Is this unique to the 05/06? I swear my 97 won't start at all if either the crank or cam sensors aren't plugged in.
New to Jeeps... Is this caused (or exaggerated) when a lift is installed or does it occur regardless of a lift? If it is "factory" seeing, wondering why this is is set this way? Thanks!!Tummy tuck is when you lift the tranny and transfer case and replace the stock (shovel) skid plate with a high clearance skid plate. The result is better clearance and it looks better
