Draining oil with engine skid?
CodaMan
California Escapee
Dover, Arkansas
Draining engine oil with an engine skid can be a hassle. What is everyone doing? I see this fitting from Fumoto, any others out there?
Stahlbus Oil Drain Valve Plug 1/2 inches-20UNFx12mm Steel 1/2" 20UNF x 12mm https://www.amazon.com/dp/B01AMXATDC/?tag=wranglerorg-20
I use a Fumoto valve with the Savvy engine skid. Easy and mess free so far. The white elbow rotates and snaps off if you don't want to leave it on there, I leave it on though. I attach a hose to it and drain directly into my container.
The skidrow plate has the drain hole placed correctly, it isn't an issue for me. When I pull the filter I just use a small tray on the skid to catch the oil but the main plug drains just fine without anything special.
Edit: looking at the pictures the Savvy skid has a much smaller hole, guess that's the difference
Reactions: Daryl and CodaMan
